w8tn4snow
I installed a bender clutch kit in my Viper yesterday and the instructions said to grind off the heads of the rivets in the clutch weights but to be careful not to grind the weights ,WELL I happened to scuff the weights just a little , couldnt help not to really . Does anyone know if this will cause a problem ? I didnt go crazy with the grinder on it or anything like that but maybe a few tenths of a thousand of material , just enough to know I did it . I replaced the rivets with some 6.1 gram ones and that got me thinking if its that sensitive then maybe i should ask someone . Any help would be appreciated . Thanks
No major problem there. I would suggest to weight those weights on scale to match.
EricMichael
yeah nothing to worry abou at all, put your rivets in and go try er out!
