SRX Suspension upgrade
voodie
Mn
I'm looking to upgrade the rear suspension on my 2000 SRX with about 2900 miles on it. Any suggestions on what it will take to make the upgrade in a reasonably costt-effective way?
Most cost effective way would be to find some Viper Take off shocks. If you are a trail cruiser look to get the updated revalved ones. If aggressive is more your style look to the non revalved ones.
i did exaclty above on my 2000 srx
you will need to extend the bottom of the transfer rods for the higher ride height/longer travel.
i set the fra ( front/rear ) to the softest setting on original viper shocks and it handles/rides great.
Ramb
Thanks a bunch! I found an '02 Viper suspension on eBay and took the plunge. I may have the shocks revalved but either way the ride will be a TON better!
