Need help clutching?????
700sx
Lake George N.Y.
I have 99sx 700 stock psi pipes/middle head gasket out the sled weights with 100lb rider about 415lb. The gears are 22t and 40b. Not sure on where to start with the clutching i have a heavy hitter brand new but what weight do i use?? I also have alot of primary and secondary springs and some other weights/helixs/gears.
What would be a good set up for ice 660'
Chad
try pm'ing turk. he has set up a lot of sxr's so can probably point you in right direction. srxmagic and docktorc are very good as wwell.
HH,s close to empty; 48/40 helix(dalton style) & green secondary spring at about 80 wrap should be a good starting point.
