Enticer 340 deluxe headlight problem!!!
RIVERRUNNER
Duluth, Mn
Hey guys, have a 1981 enticer 340 deluxe that has a problem with the headlight. When you start the sled up the headlight works fine. After about 5 minutes of riding the headlight dims for a little while and then it will get bright again. It continues to switch from bright to dim tell you shut the sled off. Has anyone ever experienced this problem with theres? Or any model that is similar?
A likely cause would be a bad voltage regulator. That would be a small box mounted somewhere under the hood. Check the ground at the regulator before replacing it.
It could also be a bad connection or a bad ground in the circuit or a bad lighting coil -under the flywheel.
