98 powervalves
srxjake
IL
I need details on how to adjust the powervalves on my 98 srx. Wher can I get the wiring harness? What are the specs?
Jake
Don't buy the harness. After you have cleaned them well with carb cleaner and a scothbrite pad and/or a razor blade(VERY CAREFULLY). Put your pv's back in.
1-take off the servo motor cover-3 philips screws.
2-start your sled and warm it up.
3-turn your idle screw down and watch your rpm untill it is under 900. This fully opens your servo motor. Kill motor.
4-mark the pully part to the housing with whiteout. This is for future adjustments.
5-remove your pipes and flanges.
6-inside the exhaust port you can feel the pv's.
7-now loosen the locking nuts on the pv motor.
8-While you are feeling the pv's in the exhaust port adjust the bolts in or out on the pv motor until the pv's are flush.
9-when flush with the exhaust port, tighten the locknut on each cable.
10-put on flanges and pipes.
11-put your servo motor cover back on.
12-start your sled and adjust your idle back.
If I have forgot anything, someone will chime in.
cheers,
mul
