bluelightning
started up the sled yesterday after draining the old fuel out and refilling it. I was hasty and and i put off cleaning the carbs till today. but yesterday i started her up...just couldnt wait to hear her and smell some sweet sweet 2 stroke. but anyway...started up after a few pulls...but in order to keep it running, i had to blip the choke. it just wouldnt stay running without it! adjusting the idle did nothing, and after it warmed up, hitting the gas killed it
any ideas? or should i just worry about it if the machine still does it after i clean the carbs? i'm thinking they are pretty well gunked up...i ran premix in the tank for the last ride after putting in the new top end, and after coming home i was too frustrted/sick of it to drain out the tank
thanks in advance for the help
clean the pilots real good!!! Are your spark plugs fouled out or look rough? Check the wires too. Sounds like it wants to run but cant.
Clean the carbs! Your pilot jets are clogged.
^^ all of the above
