what is that little unit called that control spark
98700
Wishing for snow!
Hamilton, Ont
hey guys i am some times not getting sparks and i think it is that little unit, i forget what it is called. i think the cdi box?
what do they go for i might need one soon.
600 box runs a little hotter timing, could potentially yield a couple extra horses if you always ran good fuel.
the "famous chaffed wire.." that tomseal6 talks about ....is that the wiring that goes under the engine?? and what is the recomended "fix"????
yes pull that entire harness that runs under the motor, check very very carefully for chaffed wires, tape wires individually and get some of that plastic auto flex tubing stuff you can get at any auto store insert wires into that and good to go.
