jonny8skidoo
I took the rear suspension out to grease everything and put new slides on and now I cannot get the 2 rear bolts back in with the tension of the little black springs
any tricks to putting these in??
Please HELP
Please HELP
reddog mmax 700
rope
heres what i do, i stand on the skid with a peace of rope tied around the cross shaft and the skid when the spring conpresses i tie it tight,and then just pull the skid up into place,if it not lined up just release the rope until it lines up and then you can get the bolts in...reddog
jonny8skidoo
SO do you pull the front out take the shock off ect.?
reddog mmax 700
skid
leave the front bolted in and leave the shock on just conpress it...reddog
jonny8skidoo
thanks
Ok thanks, Think I will wait for mydrunk azz budy to wake up and help
your the man posting so quick thanks
reddog mmax 700
no prob
no prob, i'm just surprized no one else chimed in...reddog
Any luck putting suspension in?
I just put mine in last week. I could not get it in without pulling out the entire suspension and then putting it in as a unit. I messed around for about and hour trying to flex it around to get the bolts lined up. No way!
Once I commited to taking the entire thing out it took me another 1 - 1.5 hours to completely disaasembly everything and compress the suspension on the ground and bolt it together. Then I lifted the whole thing in. I would never try to do it on the sled again.
