Bearing replacement help
excel V
Was doing a pre-season check of the bearings in the 02 Viper Rear suspension & noticed one feeling a little rough. It was one of the large upper rear wheels that supports the top side of the track. After removing the wheel from the skid, had to drop the suspension to get it off, it looks like the bearing is molded into the wheel. I am used to removing an inside cir-clip to allow you to press the bearing out. There is no cir-clip on this wheel. Does anyone know if this bearing is removable? Or do I have to buy a new wheel with the bearing in it? Thanks in advance.
Have to buy the whole wheel!
Unfortunatly you have to buy the whole wheel. I replaced both of mine this fall along with the two rear wheels. I got mine from PPD the same company yamaha uses. Good luck
