sxtheviper
Hi there!
As some of you probably know, I have changed the engine in my sx500r into a sx700r 01' engine.
The sled is 99% done, one of the things that remains is the tuning part.
- I havent done any work on these kind of oil pumps before, but I have managed to bleed the oil pump by removing a screw on the oilpump and I re-tighten it when there was no air bubbles in the oil line.
Does this method seems right and do you think i should leave it with this?
- Should the oil cable and the throttle cable move equal to each other?
I mean, when the throttle is 1/2, should the oil pump also be 1/2?
- Well, then to a little problem. You see, there is 3 wires from the tail/brake light in my seat (The seat is from a 00' Srx 700). That would be: Ground, tail light and break light.
But from the engines "wire-net"(Dont know the word) there is 4 wires into one connector.
As you see I have to make some sort of home-made connector.
But what is the fourth wire for? I havent had time to measure anything yet, but I will do it later today. If any of you have experienced this before, please let me know. Should i just "blind" the fourth wire?
- Last question is about jetting.
My sled runs this set-up:
Team roller secondary, stock weights w/4.5g rivet in 1st hole and 3.1g in tip,
2-3 engagement shims,
stock springs, 2 layers removed from head gasket and
22/40 gearing. Jetting: 142.5 mains
14.5 mm rollers
I mostly ride in temperatures around -13 degrees F to 30 defrees F and 250 - 2500 feet above sea level.
Would the 142.5 mains be good?
I would appreciate any help.
Thanks!
.Sxtheviper
14.5 mm rollers
Thanks!
.Sxtheviper
sxtheviper
Anyone?
On the oil pump you need to set throttle end play then adj. oil cable(to spec. then idle in that order.
i think they come up the same yes(or close)
sxtheviper
Thanks Daman!
Anyone up for this one?
Be nice if somone had a wiring diagram to post for ya,i do not
or i would post it
or i would post it
sxtheviper
Thanks Daman, but I made a connector and it seems to work just perfect. But a wiring diagram would be great. Don't know what the Orange/black wire was for, i measured about 6.8-7 V. out of it.
The 4th wire does nothing. I don't know why they even put it there. Maxdlx
sxtheviper
Thanks maxdlx! Good to know. I just isolated the 4th wire and connected the other 3.
