what is the best clutch setup with 8dn-00 weights?
sledhead6969
Minnesota
what is the best clutch setup with 8dn-10 weights?
have 8dn-10 weights on my viper and want to keep those weights but want a little harder hitting clutch setup that will be good for boondocking. what would you guys recommend? the only engne mod is a slp can.
those weights dont really have good bottom-mid range as all the weight is in the tip...where you'll be riding at lower speeds i'd get a set of 8dn-20's..whats your rivet placement?seems those weights would be alittle heavy for a stock viper..
I have the stock mountian viper clutch setup. 17.2mm rivets in/out. a green-white-green primary spring. a green secondary spring. and 45 degree helix. i have a gearing setup of a 20 tooth and a 40 tooth .
