??s on base mod for 98 srx 700
Blue Devil
canada
I was wandering is there any jetting change needed?I also have v-force 2 reeds is there any jetting changes for these?Any help would be great thanks!
i did the base mod to my 98 srx 700 i had 30 thousands of an inch shaved off the heads at a local machine shop then added 2 extra stock base gaskets for a total of 3. i sprayed them all with high tack gasket maker before i put it together. in terms of shaving the heads if you're not sure you're getting good premium fuel all the time then i'd only shave them 25 thousandths of an inch. adding the base gaskets didn't change anything for jetting in my case. can't say about your v force 2's but i added carbontech reeds to mine and my stock jetting was fine. you won't find a huge difference with the base mod but it is there and does help. after i did my base mod i ran dead even with every F7 i met and even beat a few wich is pretty good for a 98 srx. good luck
