clutch offset
If I hold a piece of square stock to the back of the primary sheave do you know what distance I should have to the secondary sheave.
try this...All I do is set the centre to centre with this tool (blue tool) it does the offset at the same time...I reconfirm the off set with a offset tool specific (gold tool) and I'm done this is done by loosening the motor mount bolts and moving the engine into specs...hope this helps...good luck
http://www.totallyamaha.com/snowmobiles/aaTECH/drivespecs/secondarysprings.htm
http://www.totallyamaha.net/forums/attachment.php?attachmentid=16645&stc=1&thumb=1
http://www.totallyamaha.net/forums/attachment.php?attachmentid=16643
http://www.totallyamaha.net/forums/attachment.php?attachmentid=16642
Offset is (15mm)
centre to centre is (268.5mm)
