nate b
- Jan 25, 2004
I want to install 9t anti ratchets on my sled that has a 2001 pro action in in. The drivers look like they need about 3/8" trimmed off. I have done some research on here, after the fact, and this seems standard. I was wondering if I could just re-drill the 2 front mounting bolts 1/2" back?
THANKS
THANKS
depends how tight your track was. i just cut mine off with a sheet rock knife and a new blade.
nate b
- Jan 25, 2004
BETHEVIPER said:depends how tight your track was. i just cut mine off with a sheet rock knife and a new blade.
Track would still fit , I had the tensioners turned almost all the way before.
redsnake3
i think you would have to move all the bolts backwards not just the front, since there is no real room to work with as in slop at the front bolt, just trim the anti-ratchets, i did it and have had no problems like many others.
bluewho
Moveing the front holes back would be hard the v plates would be in the way i would think.If they are kimpex take 1/4 off on a lathe .
nate b
- Jan 25, 2004
I'm a little worried about it ratcheting again if I machine them down.
bluewho
Its ten times better than stock even with a bit ground down.I put the kimpex on with all the old drivers so its heavy but will never ratchet again.You have to time them and there mark does not work if that is what you have.
