jeeper1010
I have a 2001 srx and recently puchased an aaen performance clutch kit. The kit came with no instructions. I just need to know where to put the weights. My srx is completly stock. The weights seem to look similar to the ones on the tip of the arm but can't be sure. They look bigger than he ones in the heel. Where do I put them? It looks like I wan't to go bigger in the heel but want to know for sure. Also, what holes do I put the secondary sping in. I am a very agressive trail rider with some lake runs, but mostly looking for better trail setup.
Call Aaen. I never even knew they sold a kit for a SRX. They should be able to tell you how to set up their product. Your stock weights have a 4.5 gram outer & a 3.6 gram inner so the only place to install a heavier rivet is inner hole cus the tip is maxxed out.
