ssian
I have a 1998 Vmax sx, twin cylinder, it has not been running in 4 years, it was stored with no gas in it and and was full off oil. It will not start unless i prime the spark plugs with some gas!, once i do this three or four times it will run perfect!, i had the carbs off today and they are perfect (no dirt)! i also took apart the choke plunger's and they are clean.
Could i have a problem with my fuel pump?
and to the pump mix her oil inside the fuel pump and then supplies it to the engine?
thanks ian
thanks ian
Did you take all the jets completly out,main,pilot,air jet.
Remove all jets and spray them all out..make sure you can see thru them all. Drain Gas Tank completly. Drain the tank, put in new gas...then let the gas run out of the lines for a about a minute to make sure all the old gas is out of the lines and pump.
Finish it off with a new set of plugs.
The oil you are seeing is telling me its getting oil from the oil pump. It just needs clean new gas now and probably a new set of plugs.
ssian
sled
there was no fuel in the tank, and i filled it up with some fresh gas and put new plugs in, also i cleaned the whole carb and took apart all the jets and cleaned them.
Fuel lines are not solid with fuel yet or fuel pump is not working anymore.
ski
check that you don't have a bad hose from the crank case to the pump
yamyrider
did you check for spark at the plugs.
TJ500
ssian said:it has not been running in 4 years, it was stored with no gas in it and and was full off oil.
thanks ian
how many times have you now pulled it over?
now
pull it 100 more times...
this is if when you prime it, it runs until the fuel is gone... if you need to prime it again to hear it run only a few seconds again, then fuel hasn't filled the carb bowls yet...
ssian
TJ500 said:how many times have you now pulled it over?
now
i was driving it, so the bowls will be full
ssian
plug
yes brand new plugs in her
yamyrider said:did you check for spark at the plugs.
