Float settings
KCCats
IL
Is there a float setting specificaly for the Ovation 2 barrel carb. Has anyone had any troubles with this carb?
Thanks from a Cat Man! ( I believe I own more Yami's than Cats but don't tell anyone)
The correct float setting is 31mm +/- 1mm measured from the machine surface where the bowl mounts to the top of the float. Hold the carb upside down and let the float rest on the needle, but not compress it. Measure from the machined surface with the gasket removed to the top of the float. It is a TeiKei carb.
Good luck,
lc
