ekholm trailing arms
OZ
yes but...
Ottawa, Ont
Does anyone know how to intall Ekholm aluminum trailing arms ...I received 4 aluminum bushing (2 control arms) and was told all my SRX hardware will work ...although the bolt doesn't fit all the way through.
Am I supposed to ream out the bushing, ...where is the bushing placed (on the inside)?
Where did you pick up those trailing arms? I had a set on my 00 srx for just over 5000 miles till one finally gave out. I would love another set. Thanks
I reemed out the bushing and installed the bushing on the inside...these trailing arms were not an easy fit but I did get them in. Hopefully I installed them correctly and can test them when it snows (if it snows).
You ae correct. They go in behind the joint.( between the trailing arm and the footwell).
