I'm going to do another 144 X 1.5 SRX and I am looking for some better gearing. Mostley off trail riding. Stock motor. Thanks
Something in the 2 to 1 should work well. 20/40 or 21/42. Low enough to pick through the trees and high enough to still get a decent speed out of it.
what drivers you using? i used 23/41 for 8 tooth and 20/40 for 9 tooth
I had a 02 SRX that I extended and a MTN SRX 144 with 8 tooth drivers.
I have 21/41 with 8-tooth drivers
It will be the 9 tooth as they offer less resistance at the bend. Thanks
LoneViper
20/40 or maybe a little lower. It's just better in the trees.
