primary spring
flying yami
gatineau,qc
what is the recommended primary spring for a 2001 srx? Right now i have a y b y. The sled is stock. In my secondary i have a 48 42 helix with a green spring. Tell me what you guys think. What are other guys running with this setup?
I ran a green-white-green and lot's of clutch weight but I did mostly lake racing.If you ride trails I would go with a lighter spring such as a white-white-white with less clutch weight than I did to mantain your back shift.
the www raises the engagment rpm some from stock (3800 to 4200?)
I have the www.
4.5gram rivits to the heel weights
51/43 helix
this setup smokes !!!!!! with either red or green secondary
major midrange accelleration
now beats buddies 800 Rev Ho's
Ramb
