Exciter 2 SX oil pump cable adjust
daman said:
You need to set throttle end play FIRST then adj. oil pump..
Is there something special about that throttle cable adjust? And how that suppose to do by the book.
yes by not adj. TEP first you are pulling open the oil pump more than
whats needed and waisting oil., or not opening up the pump enough.
you need the spec. for your sx then you can set it,call your dealer and
ask, it's always an adjustment i recomend to do.
or ask nightman for the spec.
nightmanx1 said:
Give me your Email and I will send you the directions from the service man I have.
I sent you private message about that email.
