maxwell
HC red spring 1.5 tiem longer then stock spring in viper
Is this correct, or did I somehoe get the incorrect spring?
redsnake3
it is the right spring.
Clutch must be off the crank shaft, then use a threaded rod to set that sping in.
spring
Or go to the local gym and find two guys to put it in,lol
I have put it in by kneeling on the cover but it's a pain it's esier if you have a budyy put the boldts in well you hold it down.The threaded rod works good too.
Be very very carefull of the bushing in the cover when compressing the spring. Had to replace lots of em that guys took out.
maxwell
I will use my shop press and fab an installation dummy alignment tool.
a drill press works great
INLINE4
- Jan 6, 2006
Was thinking of bringing my drill press to the lake...LOL..
