need help preparing 01 mm 700 for Revelstoke B.C
tntmax
Saskatchewan Canada
I have a stock 01 Mountain Max 700 with a 141 2" track, i was hoping i could get some suggestions to upgrade so it will be a better ride, I think i will put on a 6 " rise, but i am not sure about gearing and jetting yet, any suggestions would be much appeciated, THANKS
Gear down as much as you can; changing bottom tooth to a 40 tooth helps.. 2.4 gram inner rivet & a .8 gram outer. set secondary at 80 wrap. For jetting go up to #60 pilots; 132.5 main jets; drop needles to #2 position fuel screw out 2 turns. Been der with that exact sled.
Forgot; I have #60 pilots. $25 cdn sent to you. I think Yammie ha wants $15-20 each now.
Went to Revelstoke on the weekend and used Turks suggestions, my sled ran "AWESOME". ran it hard all weekend without a sputter. THANKS TURK
