Heavyhitter set-up?
springs
reimond I have always used the maxx performance purple or yamaha orange-silver-orange on the srx's with a green secondary spring.
So O-S-O is 35/142kg
Is engagement around 4000rpm with this pre-load? What kind of screw combo you have used for start point?
I was around 3800 with that spring.It depends on the weight displacemtnet for what kind of helix your using.I used a 54-46 dalton helix.What gearing do you have in.8t or 9 tooth drivers?
Hypermax gave me his base srx setup to start from. 51g base, 2.1 heel, 3.0 mid, 4.0 tip, 56/40 dalton. Purple front green rear. This was from my notes in 2002!
helix
reimond if your using your sled for boon docking and being a 144 I wouldn't go over a 51 initial angle go with a 51-43,50-42 some where in between there even a 49-41 will woirk well with the heavy hitters.
Thank you guys!
I know my sled is a little different so i'm looking start point and then test, test, test.
