Canadian Viper
I Purchased a Yamaha Ultra Skid Plate (Part no. SMA-Ultra-01-BU) and going to install it on a 2003 Viper. Instructions are vague, I understand aligning it up,and installing the two front bolts with washers.There are 2 holes for rivets behind radius rods, and three along the back.Do I put rivets in all 5 holes?Anything I should be aware of before I drill? Any help on this great forum would be apreciated! Thanks, Tony :
viperking
i put rivets in all the holes just don't stick your drill bit all the way in once you get through the metal and you will be fine
Canadian Viper
Thanks ViperKing!
chilli
yup, I used all 7, but the 4 fronts had the washers.....for the 3 rears, there were already rivets in the way...so I drilled on a slight angle....
Canadian Viper
Thanks Chilli, going to install Sat morn! Got all this time for add-ons, nothing better to do!
chilli
Mine turned out PERFECT!!..and the fit was also right on the money....night and day differece in the looks of the front (PS - i painted my grills at the same time)
Canadian Viper
Got It done, no, problems, looks great! Thanks again guys for the help!!
ViperXC
I see you picked color to match the Coors Light in the background, nice choice.
viperking
Sheermadness03
I have just bought a used skid plate for my 03 viper with no hardware or installation instructions, Can some one tell me where I might be able to find the correct hardware or what it consists of and a copy of the installation instructions?? Any and all help is appreciated. -Ed
chilli
If I still have my instructions, I make a scan and send it
I'll check tonite when I get home
