srxz
I am trying to get my 01 srx set up and running after re-installing the motor and not sure how to line up the clutches as the torsion arm seems to be mounted solid and do I need to do this before installing carbs and pipes. Also any tips on oil and coolant bleeding. You guys are a big help, just don't want any problems. I did a major overhaul on this sled, just need to set it up.
