Cyclinder conversion 600 to 700
MM800
Coeur D' Alene ID
Besides the obviouse (cyclinder, head, pistons and gaskets) what else needs to be changed in converting a 600MM to 700MM. The sled is a 2000. I also have a set of 97 carbs. Is the brain box the same?
Jeremy
Well, the CDI is different... it's got some timing advance on the 700 CDI. That could mean a couple horsepower over the 700 box as long as you watch your jetting, not sure exactly how much of an advance there is. Obviously you would have to change your gearing and clutching, other than that you should be all set.
