franko2176
does any one know what i have do to install front cooler guard protectors on a 99 mmax700 with the suspension still in the sled?any help would be great
drill a hole in the upper tunnel, slide the protector up into the hole and two rivets into bottom....
franko2176
i cant get a drill up there to drill the holes would it hurt to just rivet the bottom of the protectors? thanks for the input
Dnrtheil
Front protectors I just installed came with two rivets for the bottom and one philips head sheet metal screw for the top for each protector. I tossed the philips head on the tool bench and used a hex head self-tapping sheet metal screw, put a magnetic hex head bit on a long extension in my drill to get the screw into place. Did not remove the suspension either.
