Bender Pipes Question
viper48
Prior Lake, MN
I installed a new set of bender pipes for my 02 viper in November, great kit I must say, to bad we don't have any snow around here yet. My question is, the kit comes with a long spring which I have no idea where is attaches to. Anyone with an answer I would appreciate it. The directions did not mention where to attach the longer spring of the bunch that where supplied. I see there is a mount for one end on the middle pipe I believe. Thanks in advance.:yrules:
it hooks on the Bumper Backet, Anywhere and wrap it under the bracket to one of the pipes to keep it down. Im not sure which pipe it is but you will see...
I just got a new spring kit for mine. Heath (from Bender) said you take that spring and hook it into one of the belly pan brackets up front ( I drilled a small hole). Hook one end of the spring in then wrap it up and over all the pipes (where the pipes are narrowest and at their lowest point, about 10 inches in front of the flanges) That spring is to hold them down at that point, they like to bounce around. Hope that makes sence for you. Hard to explain, but i think you get the jist.
