hookedonblue
Whats The Best Chain Case Oil To Use In A 2002 Srx 700... My Dealer Recomended 10w30 Motul Motor Oil. Does This Sound Right?
JeepJimmy
blue missile
i use the yamaha gear lube but others here use atf
If you want theoretically best FACTUALLY or are you asking for opinions???? Synthetic lubricants work better than conventional lubricants... The drag coefficient is less with Automotive ATF than 90wt gear lube,,, MOLYDISULFIDE is WAY BETTER than ANY oil on the market... Energy release is the name of the product. You will have to do a search for it because i havent seen it in a few years in the sled market!!! gary O. nosboy
Sheermadness03
JeepJimmy said:
Me too. -Ed
oil
Nosboy I always add a little engery release too.I usually use atf with energy release or mobil 80weight with energy release.
I think they synthetic atf with the moly disulfide (energy release) is PROBABLY the scientifically BEST thing out there!!! (available to the public!!!)
SWEDE
Amsoil chaincase oil is 30 wt, that came directly from the amsoil tech line guy.I like that alot better than having 90 wt. in there in winter time,but its ok.
SWEDE said:Amsoil chaincase oil is 30 wt, that came directly from the amsoil tech line guy.I like that alot better than having 90 wt. in there in winter time,but its ok.
Ams gear oil has a PP of -67,, she'll flow...
plus yammie calls for a 80w
SWEDE
Interesting info,that is probably why they say more power with there chaincase oil, its thinner and easier to turn compared to 80-90 weight.
woolyviper
amsoil synthetic atf
RIVERRUNNER
I use this too!!http://www.amsoil.com/storefront/fgr.aspx
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
flying yami
nice job. how does it run?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
runs good and is less rotating weight and less resistance.
Back on topic, I normally run 80/90 gear lube oil.
Danger Dog
ATF for me.
flying yami
me too
beldt drive
flying yami here's the info on 2000srx beldt drive www.totallyamaha.net/forums/showthread.php?t=32786
sledneckdon
Mil-l-23699
MIL-L-23699 is the oil used in most Military aircraft. It is synthetic based and seems like it would be great for use in the chain case of any sled. It has a temp range from +240F to -76F
