handwarmer replacement
rancidjo
Southern Manitoba, Canada
handwarmer quit working...measured resistance and it is open. Can I replace it with a aftermarket "hot grip" that I have sittng around, or do I have to order a OEM grip?
Right as long as the resistance is the same your good,,had that problem
once,one grip was hot one was only warm..
Remember these are wired in series and power flows from one to the other if the first grip is shot the second grip may not work even though it is fine. First switch the grips to make sure the grip is bad.
Jim
