I tried to do a search for this possibilty... but no luck. is it at all possible to swap a 132' chassis and track from a Vmax into the SRX? any chance it is just a straight swap?
I am assuming you mean 93 vmax into a 98 srx as there was no such thing as a 95 srx, heres what your going to run into, the vmax chassis is wider tunnel and differnt mounting locations. It can be done but youll have to shorten the shafts on suspension and trnasfer the mounting holes measurements from the vmax to the srx. I would think it would be easier to just run rail extensions to accept the 132" track and use the pro action in the srx chassis, all ya need is a tunnel extension, you can get any length extensions made from mtn performance.
