light spring, stiff spring
EricMichael
Presque Isle, ME
I have searched this topic time after time and can't seem to find an answer...I've noticed people have said that if you use big heavy weights than you'll use a stiffer primary spring, but then i've seen people use light primary springs with heavy weights...is 50 grams of weight considered heavy?and would you be inclined to use a softer primary spring?I'm talking total force
Its all about balance. The heavy weights will over power a light spring and a heavy spring will require more rpms for lighter weights to overcome. I think a 50grm base weight is on the heavy side of normal yamaha two stroke weights (38-44) range.
