countrykrazy1
- Jan 3, 2006
First of all thank you for reading my post as I am pretty new to the snowmobiling community.
I have a 1984 Yamaha Phazer. Mileage was 8,900+ when the speedo quit working, yes the mileage is high but I take care of the sleds condition. My problem is the other day I went out and rode for the first time this year for a good 45 minutes or so. This thing did not skip a beat and it ran great as it did last year. It is when I got the sled into the garage to put it away for the night is when things got wierd. I went to shut it off by pushing down on the kill switch on the handlebars to move stuff around so that I could park it in the corner. It killed the engine as expected. As I tried to start it again, to move it it did not start. Why... well after looking at this, it had no spark??? I tried the kill switch many times of toggling it (pushing it in and pulling it out) with no such spark.
Here is my simple minded question, if I unplugged the kill switch on the handlebars and it does spark is it my kill switch? Does these engines run a open switch so if you do unplug the kill switch it will run with the kill switch unplugged? Meaning if you push it in, it grounds the spark and kills the engine?
I unplugged the kill switch, and the ignition switch and tried a known good used coil. No spark as of yet, I am new to this so I am learning as I am going, and right now... I AM NOT GOING... I am getting a new CDI module from a friend and I do have a spare primary and secondary coil ready to go for this engine.
As mentioned before, this ran flawlessly. lights were working and everything was as it was the last time I rode it last year...
Any ideas or help would be much apprechaited.
Reagrds
Justin
Reagrds
Justin
