EricMichael
Just wondering when you clean exhaust valves if the sled sounds diffrent after?I noticed my sled sounded alittle diffrent and was wondering if it was just because i cleaned them..iI checked the cables and all everything seems to be fine.
EricMichael
no ones experienced any diffrent sound after cleaning the valves? must be something else...
does it sound more responsive?Or what kind of sound?I usaually never let mine get real dirty.
flying yami
no i never experienced a different sound. sorry man.
quebec#1
Did it sound louder ! A clicking sound at idle ?
did you put points up, tapered side down. it will sound different if you have them in upside down. did you adjust them when you cleaned them?
EricMichael
it does sound more responsive...seems it anyway...but does kinda make a clicking sound when on the throttle now that you ,mention it...and betheviper i believe i put the beveled endge down..i always check that..BUT i'll tear the pipes off tonight and majke sure of that..
EricMichael
quebec#1 said:Did it sound louder ! A clicking sound at idle ?
louder yes..and a diffrent tone throughout the entire tpm range...freinds think i'm nuts but when you know the sound of your sled you notice any little change..but I almost thought it was a slight exhaust leak..that kinda sound but its not..pipes are all sealed up!oh and mind you all that the valves were cleaned 300-400 miles ago...had some carbon build up already on the outside of the valves and i'm not easy on it at any means
probably the motor is going to blow all to hell, just ride it and dont worry, its a piped viper and they never have any trouble
woolyviper
i experienced mine sounding different after cleaning, but 2 of three were stuck and it sounded like it was fouling out before i cleaned them - I think the sound after is "normal".
EricMichael
BETHEVIPER said:probably the motor is going to blow all to hell, just ride it and dont worry, its a piped viper and they never have any trouble
haha yeah i'd like to look at it that way..dont have the money for pistons right now...but i'll take a look at er tonight and figure it out
Skidooslayer687
My center cylinder valve was completely stuck, cable pulled threw the valve and when i was at a higher rpm it sounded like the machine was sluggish/bogging hard to describe but there definately was a different sound when it was all back up and running right
EricMichael
my valves are all right..not sure how to make sure they are working but the cables are all attatched and they move alittle up and down with a finger...maybe when i sealed my pipes up it made the "sound" diffrence...
blue missile
take the cover off the servo motor and let the idle go down to i think 900 rpms the valves will open i think most people are choking the to do this. and watch the servo turn.
