JENSEN
need help setting up powervalves, just got new ones in today and managed to borrow the battery lead off a friend. Anyone have any suggestions on the best way to set them up, i got a crash course from my buddy, but just want to make sure
Mike
Mike
mulderdad
Do a search on pv's. They have been talked about in GREAT length this yr.
Skidooslayer687
You dont need the battery tester tool to adjust the powervalves at all, do a search on them and you'll find that if you idle the machine below 900 rpm this will cycle the valves wide open and you do your adjustment from there
the battery tester is just as easy tho and you don't need to fire
it up..
it up..
Yps
Check this thread out...hope it helps...good luck
http://www.totallyamaha.net/forums/showthread.php?t=32721
maxdlx
VIP Lifetime Member
where do you hook the 12 v tester to on the sled? Maxdlx
redsnake3
i found mine behind the panel by ur left knee. mine had a 3 prong electrical connection with a cover on it. thats the way they come from the factory.
