redsnake3
i need a heel clicker set up for a 98 mountain srx with bender trail porting and bender big bore pipes, revving needs to be at 9200.
rx-1 helix; red primary spring, green secondary spring at 60-70 wrap 3 grams heel & tip will get ya close
redsnake3
thank you sir, you are a true genius. how do you always now all these set ups everyones always asking you for? by rx1 helix do you mean the 51-43 mnt helix?
I mean the rx-1 shortie helix. I have owned or clutched allmost every sled yamaha has made since 1997. I just wish I wrote some of this down cus I am going from memory & sometimes I just forget. anyway; this may not get you 100% but it will get you close enuff that with 1-2 small changes your good. A helix with a shallower finish will work even better.
xt700
- Jan 27, 2006
Turk i envy you, i manage to get my sled clutched close after some testing but for you to know base settings from just little info is amazing. I cant imagine how many hours you spent whith trial and error because i spent alot and cant come close to what you do.
Pat
Pat
is there a difference with hc2 hammertime?
is the set up different for hc 2 with moving heel?
