power vavles
bo98pjay
Connecticut
i have 98srx700 and was replacing o-rings and oilseals when l took #1 powervavle unit off unit came out with out the valve thought this was odd but then went to #2 samething very odd that they where not hooked up to the valve then went to #3 power valve came out with the unit hummmmm then thought well who ever did some work to this sled must of not hooked the valve back up!!!!! then pulling out #2 valve noticed that the cable worn out the power valve so that the cable came right through it then causing valve not move in or out my Question is! is this known to happen or was the cable not ajusted right on #'s 1 and 2, # 3 is fine
If the previous owner was slack in the maintanance department the valves were probably stuck in the cylinders at some time causing them to pull through the ends which is why you are finding this now.If you have access to a good machine shop do a search on power valve repair,there's a good pic and article on fixing this particular problem.If you cant find it pm me I've got it saved somwhere.
