viper compression
yamie 1
nova scotia
i just had the compression tested on my viper. the compression, when engine is warm was( when sitting on machine) 100 on left cyl , 120 on mid cyl and 125 on right cyl . can anyone tell me if this is normal. if not what would be the best corrective action. what is normal compression on a viper. i would presume that comp. should be the same on all three.
those numbers sound right. viper head has a larger dome on pto cylinder, so the compression is lower. they staggered compression to allow for straight jetting due to the pipe design.
there is a lot of info on this topic, just do a search you should get a ton of informative reading.
those numbers are good, probably around new..I wouldn't worry about it all compression testers read diffrently cause of longer hoses etc.
