ugly noise from mag side?
TJ500
Lockport, Manitoba. Canada
when driving VERY slow thru tight bush trails I hear this horrible clanging noise.... at first I thought it was coming from the chain case.... I've opened it and checked out fine... chain is tightened to standards....
when I gently touch the brakes, seems to go away until I let off..... is there so much slop on the jackshaft where the brake disc fits that this noise is possible?... how can I get rid of it? it sounds like hell...
02 MM700
its probably the disc rattling between the pads. sometimes the disc can be very loose! Try tightning, the brake caliper up a bit (parking caliper)
its most likely the disc rocking back and forth on the keyway on the jackshft, you can fix it with either a bender alum brake hub or if your cheap and want to fix it yourself, you can remove the brake disc and stake the hub with a chisel to tighten up the slot, youll have to lightly tap the hub back on the shaft with a peice of pipe over jackshaft but this will eliminate the slop and noise, bolt chaincase back on and your done.
