hookedonblue
I Have Been Told That The Br9ecs Spark Plugs Are Basically A Non Fouling Plug Due To The Tapered Edge By The Electrode. And Br9es Can Be Used As A Subsitute. So I Am Running A 2002 700 Srx. Of Course It Calls For Br9ecs, Is There Any Danger Or Fear Of Using Br9es Vs Br9ecs Plugs. Those Br9ecs Plugs Are So Dayum Expensive.
My 1998 600 Twin Venture Calls For The Same Ones... What About A Different Plug In A Different Brand.
Which Plug Is The Best To Use? And Is There Any Brand Subsitute That Is Any Better Or Cheaper Than Ngk...
98srx6
http://www.totallyamaha.net/forums/search.php?searchid=427928
Check out this link and decide for yourself which plug you want to use.
98srx6 said:http://www.totallyamaha.net/forums/search.php?searchid=427928
can't..he's not a VIP....
Don't run the es's, run the ecs's in a SRX...
Bigmax
If you're sled is set up right you won't have to worry about the plugs. I've gone a whole season, fogged it for summer, and then half the next season on a set of plugs and only changed them because I figured it was time. And I let me sled idle a lot.
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Correct me if I'm wrong, but don't the ECS's run cooler at WOT than the ES's? It sure would be shitty if the wrong plug was the cause of a burndown when going WOT throttle across a lake. You only have to replace them once a year, i say run the ECS.
Bluebozzzz
ECS plugs
electrode is made to withstand more heat not melt off, I usually do spring fogging and fall first starts with Br9es and then put ECS in when all gunk is run out
Bluebozzzz said:I usually do spring fogging and fall first starts with Br9es and then put ECS in when all gunk is run out
^Welcome....i do the same too.
hookedonblue
thanks boys. much appreciated...
akrievins
very good tactic!daman said:^Welcome....i do the same too.
akrievins said:very good tactic!![]()
yea, ive been doing that for years now them ecs's are $$$.
xsivhp
ecs's are 1.95 at Fleet Farm.
Exciterfan
Fleet Farm is my favourite place. Wish we had them in Canada!!!!
bluewho
There is something wrong C tire wants 20 bucks for a two pack of ecs plus tax thats trail prices and there are in town allmost sold out to lol
vibeline
br9ecs vs br9es
I always run the plug that is recomended by the manufacturer
BUT.......
Last year I was on a trip and I fouled a plug. when I took the plugs out I found 3 br9es's in there. HMMMMM, I couldn't remember puting those in there.
Any way I put about 800 miles on the br9es's and there was a long 5 mile lake run in there they worked fine. so in a pinch I would not hesitate to throw 3 of those puppies in there.
Check out the link below it tells you exactly what every letter stands for.
NGK plug info: http://sparkplugs.com/sparkplug411_ngk.asp
BUT.......
