seca
can any of you guys measure your rear ride height on your srx for me. i am looking for the measurement from the ground to the bottem of the rear grab bar(bumper) i am trying to see if my sled is long traveled before i remove the suspension. right now my measurement is 20". from the ground to the bottem onf the rear bumper. this is with no one on the sled.thanks .
everyone will differ as to spring settings.
true but a generalization could still help
The longtravel kits by maxx perf and pioneer, added 1.5 inches at the rear bumper. So if you can find someone to tell you there height, you will know. i think my 700 sx with viper shocks the rear bumper was 20.5, but thats from a memory that has had some damage at times over the years. Maxdlx
haha. i could measure mine if you would like but i dont have the front long travel shocks in yet(no shocks at all)
If it's the original skid it's going to be short travel,,or do you
think it has been swaped out???
seca
i think the rear was already swaped out. somebody must have a measuring tape out there in the same place as their SRX!! come on guys. start measuring.LOL!!!
TopGunnSrx
mine is 23" to the bottom of my bar with a Expert X LOL
vibeline
bumper height
I have a 98 srx with a 04 viper skid and viper front shocks.
The height to the bottom of the rear bumper is 21"
The height to the bottom of the front bumper is 17.5"
When I had stock front shocks on with the viper skid, the rear bumper height was about 22.5.
Hope this helps
Hope this helps
seca
thanks guys. anyone have a measurement with stock shocks?
troyhatt
srx
just put viper rear shocks on 01 srx mine sits at 21 inches from ground to rear bumper now. stock im just guessing at least 2 to 3 inches lower. big difference.. this should give you a baseline.
motodave289
Mine was 19'' stock 21 1/4'' long traveled.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
There is a substantial difference in the length of an SRX shock and a Viper shock. If I remember right, the big shock is about 19.5" long on a Viper totally extended eye to eye. The Stock SRX large shock is much less then that. Probably in the 17" range or maybe slightly longer. If you lift the rear end of your sled and check under there, the viper shock should be near the 19" range and the srx should be in the 17" range both eye to eye. Hope this helps.
RIVERRUNNER
I have a 99 srx with stock shocks in it and the height at the bottom of the front bumper is 14.25" and the bottom of the rear bumper is 18" with a 1.25 ripsaw. All of my shock settings are stock if this helps.
seca
thank you riverrunner!! this is the info i was waiting for. right now i have 20" with the .92 track so i am guessing it may already have been long travelled.
RIVERRUNNER
yep, I would say that you have been long travelled!!!! I wish I could say the same thing for mine!!!!!
TopGunnSrx
Dang my front bumper is at 18", I guess all that stuff really did raise it quite a bit
