black1000
A friendasked me to give his Viper a little boost so I installed a 51/43 yamaha helix with the red spring at 80. Cheap like he wanted but with no snow what am I to expect? No one has the green secondary spring so I had been looking in the search and came across that set up.
Any comments?
Any comments?
black1000
None????????? I just want to know if anyone found that top end was effected?
Your gonna overrev & be down hp with that helix. You gotta at least change inner rivet to a 4.5 gram from a 3.6 & will need more helix or go back to a 47.
S.S.Viper
Hmmm...curious aswell...I picked up a Dalton 52/42...looking into a green spring...I was just figuring anything close to a 53/43 would work good...I was told by the guy who sold it to me to put in a set of 8D2-20's with 3.6 inner and 4.5 outer...However I thought Black1000 would at least see some sorta gains...Yes/No?
Oh..and Black1000 looks like you'll be finally seeing the white stuff today..atta boy
black1000
Ya we got some. I will do some playing with the clutch on that Viper. I thought a good set up was the 51/43 with green spring at 60 or the red at 80. I can add more weight to the tip NO?
Tip is maxed out unless you install a washer under the rivet before you peen it over but watch so the washer does not go over the ramp height & contact the roller.
black1000
Turk what would you recomend? I followed your advice for my SRX and it's great. Any ideas for this Viper?
The stock ain,t bad if it,s pulling proper rpm,s. You can get better acceleration by changing inner rivet to a 4.5 gram & keep the clutching stock. Changing to a 48/40 advant-edge or 53/43 dalton works too.
black1000
So stay with stock everything but add 4.5g to inner hole in weights. I thought the 51/43 would give it better acceleration?
As long as rpm,s are good in the primary then u can play with helix,s . Get rpm,s close & start playing & look for gains.
dmaxx
Stock 8ek weights have 4.5 inner, 3.6 outer. Shop manuals are misprinted. I run 4.5 in each with 51/43 helix, g-w-g primary and green secondary spring @70 and it rips! Ran neck and neck wtih heel clicker clutched Viper until that one had a helix change, but it smokes other Vipers. RPMs are right on at 8500.
black1000
Thank you
