Since I expoded that stupid belt,I had to put on my spare belt..the OEM one.Good thing I didn't use the Utimax3 for a spare.What cheap piece of crap.Was running good rpm's for a while with it.With OEM belt my launch and WOT rpm's climbed 500 rpm.Now launches at 8600 and WOT at 9000.
Using 8DN-20 weights with no rivet inner and 2.7 outer right now.Using 14.5mm rollers instead of those 15.6mm rollers.Wrapped at 70 in secondary.What rivets should I use to drop rpm's to launch at 8200 and WOT at 8500.Here I go again.
try adding a 2.4 to the inner hole too. Maxdlx
Yes I was thinking of putting 2.44 g in the inner hole but the 2.7g in the outer hole still might be to light..right.
Exciterfan
Because the OEM belt is so hard you now have slippage.. Need more primary weight to squeeze that baby!!!
Here's my first try at set up in clutches with 8DN belt today:
Put 3.6 g in inner holes
Put 3.6 g in outer holes
Wrap is at 70 in secondary
Belt is 8DN (OEM)
RESULTS AS AS FOLLOWS:
At launch seems to be at 8200 rpm
At WOT seems to climb to 8400 rpm
If I replace outers with 3.1 g that's a total of 1.5 grams less.
It took 2.7 gram increase to drop it 500 rpm.
So 1.5 gram increase may take it up to around 8600-nearly 8700
It is a fine line.Could end up drilling thru the outer 3.6 g rivet with small drill bit on drill press thru the centre to lighten the rivet.This would slightly raise the rpm maybe to 8500.
Belt is 8DN (OEM)
