blue missile
in the chaincase beneath the gears theres a collar for each shaft but they are two different sizes and i cant remember which goes where. and the pics in the tech section just show collars and not sizes. also what is the torque for the chaincase to chassis bolts
RIVERRUNNER
I just went through that same question on friday night when i was swapping my track!!! I had to put the collars on the shafts and see where the gears lined up. I think the shinner collar goes on the bottom shaft. But the only way I know for sure is by putting the collars on the shafts and installing the gears and chain. If it lines up it is right, if it doesn't switch it around. Sorry I can't do any better then that. I hope this helps. The torque is 35 ft pounds or 48 nm
bluewho
Thats right the smaller spacer on the bottom the gear is wider than the top.
