Just wondering if skis from an Apex will fit on an SRX and if they are any better that the stock skis.
way better, they will fit, the sled will set lower on the snow, about the same on ice. spindle bolt is lower to the ski but the keal is alot deaper. you can do a front braket flip if you want the height back on the front end. or just go all the way and long travel that thing
Thanks for the info. I already have the back swapped out with Viper shocks and have the ohlins extensions on the front. Do you mean flip the front shock brakets to raise the front end?
yes, flip right for left and upside down, add a washer to the lower hole for spacing, when you bolt the shock you will see where you need to grind a little notch to clear the shock.
