clutching ?
chadman
Wisconsin
I have a 2000 srx. I run a HI Tech ER roller secondary with a 52 degree helix. I have a stiff spring in the secondary that I got from Duane at HI Tech. I have the over drive sheave on the primary with the stock spring and stock weights with 2.7 grams in the tips and stock weights in the inner hole. When I hit the throttle it jumps up to 8500 rpms and runs out at 8450 rpms. Is this where I should be, or is there a better set up? I also have a 22 tooth gear instead of the 23 tooth.
