irritating track install
blue missile
bucksport maine
when i pulled the chain case off i took the e brake and ebrake levers with the assembly. when i tried the reassemble i rolled the o ring that goes between the case and the brake rotor since i took apart as 1 piece. so i quickly replaced o ring and pulled the inner lever off. this is where it get s**tty got it all back together and i was getting ready to put the lever back on and noticed that i cant remove the bolt because off the coolant line, no problem i'll remove the bolt that holds it to the frame. WRONG the nutsert in the frame goes round and round now i'm gonna have to pull it apart again and turn the bolt around so i can put it back together.
man that blows i dont no why yamaha put the bolt in that way. when I re installed mine i put it back the nut on the bottom.
A bolt should always have its head in the direction of travel and the nut should be always on the bottom so if the nuts falls off the bolt stays in place.
