stvsrx
- Feb 17, 2006
got a 1998 srx700 with a bent front heat exchanger. my dealer says i'm looking at $600-$1K to fix, depending on if we need to replace the bulkhead or not.
is it worth fixing or should we part out the sled? is there somewhere i can get a used front end cheap?
rest of the sled is in good condition, new track and the engine runs great, only 2K miles on it.
don't really know what to do.
any opinions?
thanks
ed
any opinions?
thanks
ed
92vwgti
damnn stealership
they have outragous prices i had something i needed done to my sled went to the dealership they quoted me quite a bit i found a small shop that works on all kinda of bike..he did it for half the price and its been over 1 year and problem free
Is it bent bad??? Leaking??? I know you have to pull the motor to change this, many on here just have them welded.
Viper Treats
Post some pictures, that will really help with advice.
stvsrx said:got a 1998 srx700 with a bent front heat exchanger. my dealer says i'm looking at $600-$1K to fix, depending on if we need to replace the bulkhead or not.
any opinions?
thanks
ed
stvsrx
- Feb 17, 2006
sled is at the dealer's now so can't take any pics. coolant just pours out so hole must be fairly large. was told they'd have to remove the rear end and tilt the engine to get at it.
how much do you think the sled is worth if we sold it as is? (ballpark)
If it only has 2k miles on it I would guess $1300 as is???? Just a guess. This winter is hard on sled sales, especially ones that aren't rideable and need work done to them.
xt700
- Jan 27, 2006
Just got a price on new front heat exchanger for a 2000 SRX. 360+tax canadian. i you could do the work yourself you could cut your bill down quite a bit.
Pat
Pat
stvsrx
- Feb 17, 2006
sled is for sale if anyone wants it
$1200 obo
can deliver to southern NE
$1200 obo
Its worth more in parts then whole, the engine is worth about $900-$1000 alone. the rest will bring a good $1000-$1300+ in parts, rear skid, frt shocks,tr arms,hood,bulkhead,seat,pipes,etc.
i have heat exchangers, you could do the work yourself, 100$
YAMAHIZAL700
THis brings into question, if you have a 1" track with 1.075 woodys carbide studs. should you even need front protectors? I had one and it fell off and Ive been riding for about 500 miles that way. I did have some damage to the exchanger but only because after I changed the track and went a few miles the track loosened way up. Since I tightened it no problems.
YAMAHIZAL700
Lets see some pics of the sled.
