Concept Carbon
Ok I have a stock viper with a 53/43 green spring and stock whieghts. Is there better whieghts to run with this helix, I know hel clicker and HH would not work sense it is so steep.
mrviper700
VIP Lifetime Member
well, what kind of riding are you doing 90 percent of the time?
Concept Carbon
trail, with long straits
EricMichael
8dn's are a good choice..pretty sure u can use them with a single pipe viper..
bolin22
1. set up primary clutch to proper RPM's ...maximum torque. 2. set up secondary clutch to maximinze efficiency and proper backshift.
In my opinion you should set up the primary clutch FIRST> then work with different helix/spring setups.
S.S.Viper
I was also told to look into the 8DN's aswell...I've got a 52/42 and am not pipe......I haven't orderered em yet...but will lookin into it shortly...curious on how this set up might work myself...
Clarkster-1
- Jan 4, 2005
You can use the stock weight but your going to have to add weight to the tip to keep your rpms from over revving if your at low altitude.
